Update seems to be Buggy
Sudhanshu1
I recently upgraded my Xperia ZL to newer version namely 10.1.1.A.1.253 but after update I noted a bug & that is when you are on roaming the "R" of Roaming appears over the Network Bars but if the network is lost in between then acordingly a Red "X" must appear in place of "R" over Network Bars but here R & X both appear simultanously & looks like R is overlapping X. Please suggest / what it is?
Johan
Master
Android 4.2 is currently being rolled out gradually for this phone as we speak. Do you experience this with Android 4.2 as well?
3 REPLIES 3
Johan
Master
amfirbek92
Man we're experiencing lots of lags with 4.2..with launcher,UI,album (zoom and swap),walkman sometimes..in general anything when scrolling,chrome a lot!am not the only one facing these problems : http://forum.xda-developers.com/showthread.php?p=43151831 Is there a close fix? I love sony guys..my whole house is equiped with sony electronics but also I love the company to be competitive..sgs4 is working on 4.3 now!while we're looking to fix 4.2.2 bugs
Moreover my MW600 is running super bad especially when wifi is turned on,in terms of strengh and wifi speed when connected,i also think 4.1.2 ram management was better
Now what about all these new stuff and design we're seeing in Honami's dump?will u forget about us?or are u working to make them work perfect in the next update?(i hope so since u added the new movie app with the last update)
Xperia Z (C6602/C6603)
Thanks in advance
Sudhanshu1
Today I updated my phone to 4.2.2, I checked for that bug & now it is resolved and also the overheating of phone seems to be reduced. Thank you very much for update. But Battery Drain rate is still same as like the previous version. Hope that this will also be improved soon....:smileyhappy: Thanks Sony Xperia Team... Slightly_smiling_Face
