Wifi connection keeps dropping out
Alicelloyd
Since the last software update I have had a lot of issues with WiFi dropping out. There are no problems with the WiFi itself as it works fine with other devices but not with my Z5 compact. If I restart my phone it connects for a few minutes then drops out again. I have tried forgetting and reconnecting to the router, restarting the router and changing the channel of the WiFi, none of which have helped. I never used to have any problems with WiFi.
13 REPLIES 13
profile.country.PH.title
MarlonUk1
hello @Alicelloyd
have you tried to see if the problem is persistent while your device is in safe mode?
Alicelloyd
Not yet, I will try it later, if it does what is the solution? Thanks
Daneview
Mines exactly the same after update.
If you remove the sd card and restart it fixes it, but woth the sd card back in it happens again
YoGem
Leader
Do you use Bluetooth? Try disabling it. Also if you have a dual band wifi router could you try to connect to the 5ghz band and checking if the issue persist?
Jerognal
Same problem here after last update. Bluetooth disabled dont help. Restart the Phone for selve the problem for a while. But WiFi drops out again. 2,4 ghz or 5 ghz same problem. This happend after last update.
Vault111
Same her, airplane mode on and off seems to help. This is happening more and more often. I also notice that when wifi disconnects the wifi-calling icon is still shown.
Factory reset twice. This was not an issue on the previous build.
Current build: 32.3.A.0.378
tomago
The same problem here after update to nougar (Z5 compact A7 #.378)
Jerognal
Solved it. Just go in flight mode and back, and now my Phone har been stable on Wi-Fi since.
Alicelloyd
This has also helped mine, fingers crossed it stays working ok. 🙂
