Setting the Airplane Mode on and off, is that a one time thing? Or do you have to do it everytime you change a wifi location?
I have been holding off upgrading to Nougat because of this reported problem. I have a Bell Canada Z5 Premium. Do all Z5's have this problem, or is it by carrier or specific model type of phone?
So, does that mean that you no longer have to set Airplane Mode on/off after each wifi location change?
Sometimes the Wi-Fi connection is disconnected, while Wi-Fi is on.. Later, when the Wi-Fi is turned off and on, the problem is solved! Maybe this problem is caused by my internet connection.. I'm not exactly sure about this. I guess this problem did not exist before 32.3.A.2.33 update... It may be difficult to find a solution to this problem, Could be because of me. I'm telling you again, I'm not quite sure! I would appreciate it if you forwarded this matter to the authorities. Sorry for my bad english, I hope you understand me.
