Xperia Z5, mobile data connection
skyman53
First of all thank you for the following tip:
This is an English only forum  (This is an English forum only?)
I have no working mobile data connection with my Xperia Z5 anymore.
Measures, basic data, settings see the following list:
- The Internet and MMS settings have been downloaded again.
- The battery saver mode / STAMINA mode is deactivated
- Mobile data are activated / selected at all times
- The hook for the data connection is displayed in the status bar
- The device is running with Android 7.0
- The device software is currently
- O 2 SIM card via helloMobil / Drillisch Online AG
6 REPLIES 6
ChloeS
Contributor
Hi @skyman53,
Sorry to hear you're having issues with your mobile data connection Slightly_frowning_Face If you have already downloaded the internet and mms settings on your device and are still having issues with mobile data I would suggest contacting your network provider and asking them for the APN settings required for mobile data.
Once they have taken you through entering these on your device, restart your phone and try the mobile data again.
Let me know how it goes Slightly_smiling_Face
skyman53
Thank you, it worked.
Regards, Peter
skyman53
The same problem has reappeared. I had indeed entered the APN data of the provider and saved them. It worked, but now the data has been cleared by itself. It can not be that you have to enter this data continuously.
Regards, Peter
skyman53
I had the APN settings, required for mobile data, received from my provider and also entered as specified. If I then restart the Z5, the software for the mobile Internet / MMs is deleted and the hook in the status bar disappeared. The APN data are also gone. I then have to reinstall the software for the mobile Internet / MMs via WLAN connection and the APN data each time.
ChloeS
Contributor
Hi @skyman53,
That is very strange, do you have an antivirus of some sort running on your phone by any chance?
Let me know Slightly_smiling_Face
skyman53
Hello, yes I use the Norton Mobile Security virus protection. I already had on different mobile, without problems.Dizzy_Face
