- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
two days ago my battery ZR is consuming me between 50 and 85% in media server and do not understand why?
when I check the battery usage :
-media server used 50% (sometimes 85%)
-screen 25%
- cell standby 11%
-Android system 8%,
- phone idle 8%
- wifi 6%,
- os 4%
-voice calls 3%
-Clean master 3%
-phone 2%
normally the screen was the highest value and for some reason the media server up a lot
When I click on the media server, I can see the percentage used and below says: "battery used by the application" but I don´t know to which application refers to deactivate it. I can not find what the problem is but that is consuming a lot of battery. Help me please!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That is odd, however have you tried simply performing a restart of the phone followed by a full charge to see if the problem continues?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'll try ... thank you very much.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
but what is the media server, what works, is an application or is activated when an application is installed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
