Z1 Compact Ring Volume
briant566
 Questions coming thick and Fast Now
I missed two calls today
I acept that ring Volume is Low but what had happed is  I must have lowered talk volume and this also lowers Ring Volume which it has not done on my other Phones !
1 )  Can ring volume be set at full but not change when ajusting other volumes
 2 )  can you make volume louder
 I have downloaded volume manger app but did not work  shows full volume for ringer on screen but when you look at setting still on half  so it does not show correct or increase it
briant566
 Just tried it you are right must have been something wrong or ajusted it in settings
Thanks
3 REPLIES 3
Uliwooly
to adjust the ringer volume you can go to settings or if you are on the homelauncher just turn up the volume, as for the call volume adjust the volume while on a call, this will only affect the call volume NOT the ringer
briant566
Thanks
Uliwooly
Anytime Slightly_smiling_Face
