Z3+ cracked screen - accessing data
Ugly
Hi
Reaching out for help, just cracked my screen on my z3+.  The phone is now locked as the keyboard is unresponsive.  Is there a way of accessing the information (contacts, pics, apps etc etc) without unlocking it?
Thanks in advance
14 REPLIES 14
Megachip
@Megachip wrote:
Do I need a special OTG Adapter for Z3+? Cause all OTG Adapter I've not working with it Slightly_frowning_Face
Or do I have just reboot the phone to get the Adapter working?
Anyone? Didn't want to switch off cause than I have no chance to enter the pin anymore.
P.S. Android 7.1.? is running on the device (if this is relevant).
Megachip
So the answer is yes Winking_Face Just reboot with connected OTG Adapter.
Next question: Will it backup all the app settings? I do not found a checkmark for apps, just for contacts, sms, pictures, videos and so on...
Tags (1)
Uliwooly
@Megachip
which app settings are you referring to, for the most part those are stored on their servers like game progress.
smudger11
mouse will not work if phone is on when all connected, turn phone off connect everything make sure mouse is on and turn phone on it will detect it then use it also if you remove the micro usb or turn mouse off whilst your connected you will lose mouse again and will need restart phone,
Megachip
@uliwooly wrote:
@Megachip
I referring the settings which hopefully **NOT** stored on any clouds (and selled to 3rd party). E.g. c:geo database and so on...
