Hi
Reaching out for help, just cracked my screen on my z3+. The phone is now locked as the keyboard is unresponsive. Is there a way of accessing the information (contacts, pics, apps etc etc) without unlocking it?
Thanks in advance
@Megachip wrote:Do I need a special OTG Adapter for Z3+? Cause all OTG Adapter I've not working with it
Or do I have just reboot the phone to get the Adapter working?
Anyone? Didn't want to switch off cause than I have no chance to enter the pin anymore.
P.S. Android 7.1.? is running on the device (if this is relevant).
So the answer is yes
Just reboot with connected OTG Adapter.
Next question: Will it backup all the app settings? I do not found a checkmark for apps, just for contacts, sms, pictures, videos and so on...
which app settings are you referring to, for the most part those are stored on their servers like game progress.
mouse will not work if phone is on when all connected, turn phone off connect everything make sure mouse is on and turn phone on it will detect it then use it also if you remove the micro usb or turn mouse off whilst your connected you will lose mouse again and will need restart phone,
