CDX-GT35U display
profile.country.en_GB.title
wawamoz
CDX-GT35U display
Hi All my CDX-GT35U display always reverts to Sony's default display after a few minutes. This consists of stuff I already know about the radio, I want it to stay on the clock or programme info. Can I fix this and how? Thanks
Drumzman
Hi wawamoz,
It sounds like you have the demo mode switched on.
I think to turn this off you hold down the select button until the setup menu appears.  Then repeatedly press the select button again unitl 'Demo' appears in the display.  Turn the volume knob until the display says 'demo-off' and then hold down the select button again to exit the setup.  Hopefully that should be it.
Hope this helps.
2 REPLIES 2
Drumzman
Hi wawamoz,
Hope this helps.
wawamoz
Hi Drumzman
thanks! You were right and it's fine now.
