Sony Xperia 1V, Version and eSim question
hehduda
Hello all,
I will soon receive my Sony Xperia 1V (256 GB black). I wonder what version it will be and if the Xperia 1V is eSim capable.
Any help is appreciated!
Thank you
Andreas
Edit: I live in Germany
3 REPLIES 3
hehduda
Thank you @Marino.Manolo
your links are very helpful.
according to freenet the service provider I preordered my 1V, the device will support eSim. So I think it will be the XQ-DQ54 variant.
Regards
Andreas
hehduda
Some final information:
it is the XQ-DQ54 variant.
eSIM and dual SIM working fine.
