I bought my Sony TV model no KD-55XH9505, on the assumption that it had freeview included, but I can't find it anywhere.
Going through the Sony support page is about as easy as navigating a maze
I'm not very tech savvy , so any help is gratefully appreciated.
Hi @Merdugneo2
If you disable YouView you will get Freeview. You cannot have both.
I don't have your particular software running on my TVs so as a general guide:
Home -> Settings -> Watching TV -> Channels -> Channel setup -> YouView setup -> Disable YouView.
Note by disabling YouView you may disable some of the iPlayer Apps.
SRory I never got back to ou, but I gave up in the end.
However I tried again last month and finally managed to di it without having to disable You view, so win win!
Sorry it's Ben so long in coming but thanks for the input .
Sorry even 🤣
Sorry for the spelling, predictive text is a bit of nightmare 😡
