Sony a7r III horizontal lines
Mhdbeiruty
Hello Everyone
I just got a Sony a7r III, when I looked at the camera screen, I found these horizontal lines on the screen shown in the attached photo, the screen works fine when the camera is turned on, but these strange lines appear only when the camera is off, is there any advice or explanation for this issue or this is kind of factory defective.
Thank you in advance
Tags (4)
1 REPLY 1
That's not a fault it's due to manufacturing process and nothing to worry about.
I can see the same on my camera.
Peter
