I have connected my TV to
I have set-up TV box on the television to Sky Q
Sonos Playbar only accepts IR.
If I connect the remote using Bluetooth then I loose the ability to change the volume on the player but I can control the Sky Q box with the pause, play buttons etc.
If I disconnect the remote from Bluetooth then I can control the volume on the Playbar, but then I can't control SkyQ and I also loose voice control from the remote.
Interestingly the Sky Q remote can control the Playbar volume and also handle voice commands. So it would appear their remote can transmit IR and Bluetooth. Well done Sky.
I have seen written somewhere that the remote can't function with both Bluetooth and IR. Its one or the other.
Has anyone found a way around this?
Hey AndrewMarkD, are you talking about the Sony remote or the Sky Q?
Oe even the SONOS remote?
Hey royabrown2, I hope he answers! It seems like something is completely wrong here
