How to change or select different apps while sending a song
Adeeb
Would be great if any one can help me how to change the song sending preference. While sending a song through bluetooth or wats app i have selected bluetooth as always now i am trying to change it so i am not getting option to select other apps.
profile.country.RO.title
_alexdon_
Settings-apps-all-media storage,clear defaults.
alexdon
4 REPLIES 4
_alexdon_
alexdon
Alexander1
Champion
Go to settings > apps > find the app that you selected as always > clear defaults.
Adeeb
Thanks...its much helpful.
_alexdon_
Anytime.
alexdon
