BDV-N7200W problem: always stuck in HDMI1
profile.country.US.title
tonsmi
At this moment I suddenly cannot use my home cinema set BDV-N7200W anymore:
The unit responds to power on/off from the remote, and goes to HDMI1.
After that the "light snake" keeps blinking forever and there is no response at all on any other remote commands.
If I connect an input signal to HDMI1 and a tv to the output, no signal is coming through..
(help !)
4 REPLIES 4
EdwinaU
Hi Tonsmi,
Welcome to the community.
Your player may need a repair but we'll check into this and get back to you as soon as we can.
Best wishes,
Ed
Vanilla_
Contributor
Hi tonsmi,
I've looked up any solutions to this. I could only find a suggested workaround, that you try to unplug the player from the mains to refresh it and replug it back after just a couple of minutes. Also, you can try to disconnect any external devices to the player to check if this solved the situation.
Vanilla_
John9084
Mine is the same have to unplug or reset every day getting sick of this all lights just keep blinking all the time no sound till I unplug and start up again till next day it’s the same again . This is a replacement as I bought it just before lockdown that one the wrong sound was playing from wrong speakers wish I’d never bought this .
Joe_Dohn
Specialist
Have you tried updating it to the latest software version?
