Soundbar SONY HT-ST5000 not connecting to mesh WiFi
Hi there,
I am unable to connect my Sony soundbar to my mesh WiFi system (Tp-Link Deco M9 Plus). I have disabled 5Ghz in the mesh wifi (just in case) but no success yet. If i try to connect to the wifi of my regular router, it works flawless. Is there any known issue that causes this failure connecting to a mesh wifi?
Hopefully this has an easy solution or fix.
Regards.
Tags (3)
1 REPLY 1
Win_88
Specialist
That's weird. Is the Sound bar the only device with problems connecting to the Mesh Network? What happens when you try?
Win_88
