Hi there,
I am unable to connect my Sony soundbar to my mesh WiFi system (Tp-Link Deco M9 Plus). I have disabled 5Ghz in the mesh wifi (just in case) but no success yet. If i try to connect to the wifi of my regular router, it works flawless. Is there any known issue that causes this failure connecting to a mesh wifi?
Hopefully this has an easy solution or fix.
Regards.
That's weird. Is the Sound bar the only device with problems connecting to the Mesh Network? What happens when you try?
Win_88
