my sony xperia m2
joan_23
my sony xperia m2
Good morning i would like to ask why the sound of my m2 when i play games does not function properly the sound is too soft you can hardly hear it. I adjust all the necessary settings in full volume just to test if i can hear the sound but its still the same. I install the same game to my other device and it plays with normal sound. Pls advise. Thank you.
34 REPLIES 34
profile.country.RO.title
_alexdon_
No,task killers are not needed as Android will close apps by itself when running low on memory. But it is your choice.
alexdon
joan_23
Can you please tell me more? i'm new to smartphones. thank you
greengumy
Hey Joan
I had avas antivirus, and master cleaner on all my phone, and it is safe to say u don't need either. since i got my M2 Aqua, antivisures, and cleaners are useless.
Usethis:
setting-> developer options-> apps->check "don't keep activities" (this will clean your activities)
also, if anything is ot working well try this:
settings->Apps->scroll to"All"->find app tha is not working fine-> clear cache
Also as far as I know (i have some smartphone experience) viruses u might get on mal, ca't actually harm android devices.
I have never had a problem, and i have downloaded all sorts of things from emails and/or websites.
joan_23
Thank you for sharing your views, it'll help me a lot. May i ask what is this that keeps popping on my screen everytime i open my apps, (fb,ym,google) iy says (0 matches found) are you familiar with this?
_alexdon_
Can you check if the same message occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
joan_23
hi when i turned my m2 into safe mode nothing popped (0 matches found) what app should i disable? am just a bit worried
_alexdon_
So you do not have any kind of antivirus or performance enhancers?
alexdon
greengumy
Don't panic. Can u make and attach a screenshot ? It's probably nothing.
joan_23
I dont have any antivirus, i disable my fb account and nothing popped,
_alexdon_
Maybe you could only clear data for facebook app.
alexdon
