No,task killers are not needed as Android will close apps by itself when running low on memory. But it is your choice.
Hey Joan
I had avas antivirus, and master cleaner on all my phone, and it is safe to say u don't need either. since i got my M2 Aqua, antivisures, and cleaners are useless.
Usethis:
setting-> developer options-> apps->check "don't keep activities" (this will clean your activities)
also, if anything is ot working well try this:
settings->Apps->scroll to"All"->find app tha is not working fine-> clear cache
Also as far as I know (i have some smartphone experience) viruses u might get on mal, ca't actually harm android devices.
I have never had a problem, and i have downloaded all sorts of things from emails and/or websites.
Can you check if the same message occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
So you do not have any kind of antivirus or performance enhancers?
Maybe you could only clear data for facebook app.
