Update 15.5.A.1.5 Error
Mashraf92
I updated my phone back in June 2014 to 15.5.A.1.5. Few days back I tried to root but failed and stuck with bootcycle.
Thanks to God I flashed the same build generic India. The process completed successfully and my phone was back from dead. Now problem is that I'm getting the same build update from update center. Tried to install but it gives an error every time.
Thommo
Have you unlocked you bootloader or is your phone rooted - if it is then there is your issue and the reason why it fails - You need to if rooted use Titanium and freeze the update centre
2 REPLIES 2
Thommo
Mashraf92
Thanks,
Now my bootloader is unlocked and it is now rooted. And I used another method to stop that annoying notifications.
