I updated my ck15i with SEUS. I tried to get to the internet through my wifi but all I get is the blank blue background. Nothing opens. I have tried to use the youtube, facebook, even twitter app all I get is the blank screen :
I tried reinstall update, but not working. please help me.
OK, if your phone has the Allow local connection setting (under Internet settings), then make sure this is switched on. Otherwise, I suggest you re-run the update service on your phone and failing that, try a master reset. Hope this helps.
Does this happen with other wifi networks as well?
yes. i tried other wifi but not working.
in internet settings isn't Allow local connection setting. there are homepage and connection point. i tried a master reset but still doing it.
http://talk.sonymobile.com/thread/36836?tstart=0 OK, have a look on this related thread and see if there is a solution here.
thank you very much. i open internet settings and create connection point. then i open browser and internet apps and work fine. thank!:smileycool:
No problem.Can you please mark the question as correctly answered.
hello......i have same problem after updating internet apps are not working and blue blank screen is appearing every time could u please tell me...how to create a connection point ...what is to b filled in
APN,DNS ADDRESS,LOGIN REQUEST,NAME,PASSWORD,,,ETC WHILE CREATING A CONNECTION POINT...PLZ HELP ME...
