Hello
I want to upgrade to 4.0.4. through SEUS, but I can not enter in flash mode, press the Volume Down button and connect, and the computer freezes.
Please tell me what could be the problem.
I have a PC with XP and it works just fine
So the problem I have.
I'll try to reinstall the system software (DirectX, Flash Player).
Well, now I at least know why.
Reinstalling the system software does not help.
Do not even know what to do.
try this
create a new administrator account -> install SUS -> restart your PC
try again
There is none.
Maybe there is some kind of authorized service centers that can help?
The problem with the flash mode of thought suggested to me the guy with the nickname vladigor from the site 4pda.ru.
I went into safe mode, connect the phone, the driver is installed, and you're done.
Thank you for your attention you paid to my problem.
that's what I said earlier
the second message
http://talk.sonymobile.com/message/219611#219611
try SUS if it doesn't work restart your PC -> press F8 -> safe modeDon't forget to mark
I certainly did not understand the phrase, but right now it worked, I'll be updated on your instructions.
