I can not update
Not applicable
I can not update
I need help
when you upgrade, this message appears "Unable to install or start the software components of your phone"
which the cause of this error?
gwhispererz
Champion
Hi, did you try updating phone with Update Service? Anyway, here's the download link, http://www.sonymobile.com/gb/tools/update-service/. The other option is to use another PC/Laptop.
I guess you are aware that this process will erase phone memory completely.
3 REPLIES 3
gwhispererz
Champion
Not applicable
now could to upgrade to new version
thank you gwhispererz:smileyhappy:
gwhispererz
Champion
No problem ....
