Problem with menu button after android update
Sin119
I've updated my phone to 4.1.2 android . Before the update, when I press & hold menu button down, i get options to bring up mini apps (timer,notes) and to swipe & close running apps.
Now after update, it brings up google app. Is there a way to customize the menu button? Any suggestions?
profile.country.RO.title
_alexdon_
To get the task manager,tap twice on home.You cannot customise unless you root.
alexdon
3 REPLIES 3
_alexdon_
alexdon
Foxy_coxy
On My xperia z tab after update they have moved the menu buttons to the middle is there anyway of putting them back to the left hand side it was so much easier
_alexdon_
Nope,it is standard.
alexdon
