Screen dump feature in ICS/Android 4.x
Not applicable
Since upgrading my device - SonyE Xperia Arc - the screen dump feature's been gone. A very nice feature, handy with the on/off-button. Why have You trashed that one. - BRING IT BACK with a fix ASAP!
Aimee
Enthusiast
The screenshot feature is still available. To take a screenshot, you'd now need to press and hold both the power key and down volume key at the same time. Holding these keys will automatically take a screenshot on the handset.
What do you think about this forum? Let us know by doing this short survey
1 REPLY 1
Aimee
Enthusiast
