Just bought KDL-32WD754. Signal is too slow to run Netflix/apps even though ipad and iphone when put next to TV show their connection speed is 45 mbs. Have updated to lastest firmware and rebooted BT Hub but no luck.
Hi Lucas442,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi Lucas,
Have you tried connecting to a different network, like a mobile hotspot for example?
Cheers,
The_Black_Rose
Thanks for that. I gave up in the end and bought the BT extender which works.
