tv side view (KDL-42W650A) on iOS7
farkasb86
Dear Sony,
I purchased a KDL-42W650A TV which is absolutely stunning!
I read in the advertisement I can use my iphone as a remote. All I have to do is download an app called Tv side view.
But there's no TV side view at the apple store.
So how should I do it?
Anonymous
Not applicable
3 REPLIES 3
Anonymous
Not applicable
Hi there
Is this what you are looking for:
https://itunes.apple.com/gb/app/media-remote-for-iphone/id373459732?mt=8
profile.country.en_GB.title
Catmambo
Contributor
Media remote will likely still work but its the old controller and unlikley there will be further updates to it to make it iOS 7 compatible AFAIK.
Odd as TV sideview seems to be missing from iOS temporarily. There is definitely an iOS version available as I have it running on a tablet. I'll check and find out whats happened to it. Maybe a temporary glitch in the app store?
Catmambo
Contributor
Just checked and its back on the App Store, so should be ok now..
Thanks
