vaio vgn s1hp
voyocks
vaio vgn s1hp
The scrolling function of my laptop has stopped working.Any ideas please.
11 REPLIES 11
rich912
Contributor
Hi voyocks and welcome to the forum.
Are you referring to the scroll function of the touch pad?
Go n-éirí an bóthar leat
voyocks
Thanks for the welcome. Yes it`s the touchpad scrolling function.
Thalamus.
Champion
Hi voyocks,
have you turned scrolling off..
Your set-up may be slightly different but this may help you to check..
Click on Start, then click on Control Panel.
In control Panel select Mouse.
In the Mouse Properties window select the Function tab.
Is Use Scrolling Function enabled.?
voyocks
Hi .thanks for the reply. vertical scrolling is enabled.it refers to a mouse though and not touchpad.
I have been using a wireless keyboard and mouse and wonder if i should uninstall them to see if it makes a difference.
rich912
Contributor
Hi voyocks,
This would be a good starting point.
In Device manager right click the mouse and select uninstall - then, without the wireless keyboard and mouse attached, re-boot and let Windows re-install the correct drivers for the device...
voyocks
Thanks for the reply.Is it any different uninstaling from device manager than control panel add/remove.?
I`ll set a restore point just in case. Is there any risk of it upsetting the touhpad or pointer in any way other than the result i`m hoping for.(always a bit shy of this kind of operation).
Thanks again
Thalamus.
Champion
Yes it is..
What do you currently have listed in device manger under mice and other pointing devices.?
voyocks
Microsoft PS/2 Port Mouse (IntelliPoint)
rich912
Contributor
Thereby hangs the problem - it should list a pointing device...
In Device manager right click the PS/2 port mouse and select uninstall - then, without the wireless keyboard and mouse attached, re-boot and let Windows re-install the correct drivers for the device...
