So it happened the 2nd time playing regularly songs with automatic optimization on and then it happened, huuuge distortion bass went up like crazy it made my ears hurt
can u guys look into it.
regards
Dion
We have found the cause for the sound distortion you may experience when automatic optimization is enabled and this will be fixed in a coming software update.
To work around this until the update is available you can turn off automatic optimization.
Same issue, ever since new update. Headphone optimisation is broken.
Same problem with my Z5p. My headphone is xb950bt. Fix please.
Thank you Rickard.
Your instructions solved the issue temporarily.
Please let us know when the issue is fixed.
Regards.
I have the same problem on my phone, even if I turn off or on any of the settings around audio optimization.
