Problems after Update
Gercce
Hi!
I just updated my XperiaZ1 this morning and now it crashes and starts again every few minutes. What's the Problem and how can go back to the old version? I really can't work like this - so please help quick!
Regards G.
8 REPLIES 8
Hampus
Champion
Does it crash/restart when you do something specific? I suggest that you boot your phone into safe mode to see if you experience the same behaviour:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
But if this behaviour appeared after a software update, a software repair via PC Companion would be recommended:
http://www.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
Follow the instruction that appears in the program and do not connect your device until this guide tells you how to connect it.
Gercce
Thanks for the quick answer!
It does it all by itself, without me doing anything - that's the strange part...
I'll try your recommendations and see if I can fix it.
Regards G.
Gercce
It still switches off and on after I did what you recommended...
1st It crashed/restarted also in safety mode
2nd I did repair it via PCC but it still crashes
What else can I do? It must be the Update I did, so is there a possibility to go back to an older version?
Gercce
Now, I've done what you recommended - it switches off more often and because of that, I can't restore the saved data. Now I can't use the phone and have no possibility to contact my business partners because not even the data is on my phone.
Do you have any recommendations left or should I just get a new phone?
It worked fine just before the Update, so there must be something wrong with the Version 14.4.A.0.157...
I was quite happy with this phone for a long time - just minor problems, but now I'm really disappointed.
Hampus
Champion
Unfortunately, it's not possible to downgrade to a previous software. If it was a problem with this software, everyone would experience this behaviour which is not the case. Have you tried to start the phone without SD- and SIM-card to exclude problems related to them?
But if the problem persist, I suggest that you visit nearest service center to have your phone examined by a technician. You can contact your local support team for information about nearest service center and/or how to proceed with this in the best possible way:
http://www.sonymobile.com/global-en/support/contact-us/contact-info/
Gercce
We're getting closer - I removed the SIM-card and it didn't switch off.
So I put it back in and after I switched off the "mobile data" it didn't switch off either.
Do you have any idea what it could be? Is it the SIM card or sth with the phone's connection?
At least I have the data back to make calls, and I think the other problem can be fixed as well...
Thanks!
Hampus
Champion
If you activate mobile data, does the phone switch off? If yes, it may be related to your SIM-card. I would suggest that you try another SIM-card in that case.
pratikc
Hi. I too upgraded my z1 last night n now vibration alert is dead.
