Strange Charging Issue
Elantramax
Hi all. Got out of work the other day. Plugged my M2 in to my car charger. It wasnt charging. OK it was very hot outside that day. So I waited until the next morning. Same problem. Stopped at a store on my way into work. Purchased a New charger (1A Capacity). Tried it. Phone wont charge inside my truck. The Fuse to the power port is good. Phone will charge when connected to a AC outlet though a USB adapter. Even charged off the USB port on my pc. For some strange reason, It wont charge inside my Tucson?? With 2 different chargers. All I got was a couple of green flashes then went out.  It worked before.
22 REPLIES 22
CameronT
Champion
@Elantramax,
It will depend on the local policy of your support team, in general though, they are unable to assess international products. You will have to talk to them to discuss your options, and if possible, you can contact the seller to determine the country of origin of your handset. I still believe the issue is not with the phone however.
Elantramax
I have tried 4 chargers, 2 different vehicles. AT&T Store Tested my charger in front of me. And it worked on his phone. Not on mine. I went to the local Radio Shack. They tried to sell me an External Battery that connects to the USB. And it didn't work on the M2. But worked on the Managers phone. When I get the money, I am replacing the phone.
Elantramax
I ended up replacing the phone. Thank you for your help.
