unlock password
aisha
unlock password
my pattern lock is correct for my sony xperia S, but unfortunately I cannot unlock my pattern on my mobile,dont know why.. i even forgot my "forgotten password".. im so much tensed as I cannot access my mobile since long!
3 REPLIES 3
Nabeel
Master
Don't you get the option to sign into your email ID ?
If not then there's no other way to solve your problem than this >
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via SUS
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
http://www.sonymobile.com/global-en/tools/update-service/
cameraman2
sir
My sony experia e3 model which i purchased a few days back the key pad has been locked and i could not open it as i forgot the pin kindly help me out.
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
