- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
October 2016
October 2016
I got my new xz and upon using the charger and another qualcomm certified 3.0 fast charger, the mobile is not charging fast even the message is only charging
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
October 2016
The message will not say fast charing like other manufacturers phones. SONY should make this fixed in software update ( please )
But if you have a proper SONY UCH12W it will fast charge ( I know because I have one )
16 REPLIES 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
October 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
I have the same problem. I bought an anker and another brand charger certified to quick charge 3.0 and nothing but the usual slow charging happened. What to do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
Get a battery management app like GSam battery monitor. That will allow you to monitor your charging and discharging amperage rates. The XZ will not notify you that it is fast charging, it just does it. When you see charge rates upwards of 1.8-2.2amps on a 3000mah battery, that's fast charging. Any time you charge a lithium battery faster than .5c, or half the capacity per hour (1500mah for a 3000mah battery) that is considered fast charging.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
I hope to be considered in the next update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
at what level are you charging the device.? if you are charging it from 0-80%?.. it might say fast charging but remember from 80% onwards the charger will slow down .
also try to use stock or pre installed themes
you can also time your charging when you are safe mode
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
November 2016
November 2016
My XZ can go from 0-50% in half an hour on the stock charger, which is fast charging in my book. It gives me a sufficient boost to last several hours
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2017
February 2017
Think, Sony aware of the problem and correct it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2017
February 2017
I agree with Sunking101, I got the same charging rate with stock charger.. Therefore what's the advantage of third party charger when what you have can already do it fast.. What's the desired charging rate do you want with such additional accessories..?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
March 2017
March 2017
Really? Because i just bought chinese brand of qualcomm 3.0 fast charge but i noticed that not much fast charging. How fast u use the sony uch12w?
