Since the last update to pie9 everytime I get a missed call the notification doesn't clear off my screen no matter what I do. Before this the notification would clear after going into the calls. Has anyone else got this issue or have any solution?
Seems similar to this
/t5/Xperia-XA2/call-notification-issue/m-p/1383346#M2292
could you try those suggestions?
Thankyou that worked, let's hope I don't have to do this everytime though, it's so annoying. Thanks mate 😊
anytime
Tried works then still the same afterwards
I think I've worked it out - it happens when there's a missed call with a voicemail and it doesn't clear until you've listened to it
I have the same problem, on a Xz1 and my wife's new 1.
Yeah I thought I'd worked it out by listening to the voicemail but it's done it again and I've no outstanding voicemails so don't know. I've changed my phone now to a Sony Xperia L3 so let's see if it happens on there or not once I'm up and running on it
This Problem is Very annoying no voice message no call history still says missed call. Had sony phones for over 10 years never had 1 that did this
What model have you got? I'm the same, had Sony phones for the last 6 years and only had this problem on the Xz3 after the last update. I've now changed to the L3, and I don't have the problem on this one. It is annoying though isn't it. I hope it gets sorted I like the Xz3 but that was getting right on my wick!
