Xperia XZ3 Multiple user accounts - micro sd card problem
tdrenjan1
Hello everyone!
I would ask for help.
I use two accounts on my device.
Formatted micro sd card on administrator account is invisible on second account without re-formatting on second account.
After formatting on second accound is invisible on administrator account (until re-formatting on administrator account).
I can use micro sd card only in one account.
Is this bug on XZ3 or only on my device?
Thanks
tdrenjan1
My experiences:
XPERIA XZ3 - H8416
I had problems:          1. micro sd card does not work on Multiple user accounts
                                      2. Cannot connect to screen mirroring
                                      3. During phone call my ear hits mute button
                                      4. GPS - wrong location
                                      5. not recognizing the new WiFi network
                                      6. wireless charging stops after 2-3 minutes of charging
After contacting local SONY support and carrying it to an authorized service center (4 times - they allegedly change of motherboard, changed the whole device ...) the problems remained the same, only the IMEI number of the device changed.
I reported material defects on the device to my provider (from whom I bought it), and after a few months of straining, I got new phone - model - H9436, which, for now, is working properly.
I've been without a cellphone for 11 months (nobody even apologized).
Sony Support and service are catastrophic.
This is my last Sony device...
Best regards
7 REPLIES 7
profile.country.PL.title
najodleglejszy
@tdrenjanI've requested some more info about it.
Lord_viridis
Sounds like a security feature to me, imagine if some Trojan created a second account in order to access the full sd contents.
profile.country.NL.title
Strampke
@tdrenjan
Checked and confirmed on my own device.
It is like it is isn't it?
Filiberto125
Facing the same problem, please help me. kodi
profile.country.AT.title
skycamefalling
Contributor
It's not a problem, it's a security feature.
If you need a second user account, for whatever reason, it has to do without the SD card.
tdrenjan1
If this is true, then this is a big security failure.
The second user can format the sd card (and delete all content) and use it until the next reset of device (or while another user does not format it).
But the user guide says:
By adding custom accounts you can allow different users to have different home screens, backgrounds, and general settings. They also get separate access to applications and memory storage for files such as music and photos. You can add up to seven regular user accounts to your device.
It works perfectly on Xperia Z3.
tdrenjan1
My experiences:
XPERIA XZ3 - H8416
Best regards
