Cant turn on my Xperia Z
bamdp
pc companion was alt tabbed and the downloading was nearly finished. then suddnly my phone was off, my battery life was above 45% and now i cant seem to turn it on.
When i turn it on it just shows the sony logo then after a while , it shuts down
when charging, red led, the screen light up w/ sony logo.. then off... after a while it repeats.
same via usb connection.
Uliwooly
install SUS on your PC then follow the steps
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
17 REPLIES 17
Uliwooly
try this
connect your phone to the wall charger, not the dock, press and hold power & volume up for few seconds until the phone vibrates > let it charge for 1 hour > AFTER 1 HOUR >
install SUS  on your PC > restart your PC > disable your firewall and antivirus > run SUS > follow the steps
Uliwooly
Uliwooly
remember that neither PCC nor SUS (or Bridge) will work if your phone has less than 50% of your battery
bamdp
ill check after an hour. my phone is now connectd in wall socket. il check. thanks sir. i hope this can cure Slightly_smiling_Face Slightly_frowning_Face
Uliwooly
keep us updated
bamdp
ok currently downloading SUS, phone is still charged and still the same condish. tried the power+buttn + vol up, it vibrated then followd by 3 vibrates, then still the same. :S
Uliwooly
does the LED turn on or change color while connected to the wall charger? have you got your phone wet?
bamdp
how do i use SUS to my xperia z?
bamdp
hmm its still red the led turns on then screen on wid sony logo. then off. i unplugged it and connected via SUS on my PC.
. i managed to do the SUS thing, and
2 options appeared,
1. software update
2. factory reset.
1 or 2?
