getting hot quickly
jayz960
getting hot quickly
i  bought xperia z1 4-5 days ago
this phone is good but if i brouse web for 10 min it get super hot  and even when calling it get hot
237 REPLIES 237
morthren
I wouldn't say it's supposed to heat per se, more like application use = processing power which in turn generates heat and subsequently consumes battery power. The app I've found that generates a fair bit of heat is Google Hangouts. It is bearable though as you don't tend to hold the phone to your ear.
profile.country.RO.title
_alexdon_
Yeah,also syncing on all the time and apps that are permanently connected to the internet.
alexdon
factualstory
I have heating problems too it must be a design fault in the phone as I have no heat problems with other mobiles in the house ! Phones should be recalled !
factualstory
It is a clear fault how can excessive heat be normal ? How many mobiles have you owned which heat up excessively even on cool days ? None of my other phones in the house heat up ! Give honesty and a chance and call it for what it is......it is a fault !
ansar
Updating android to higher version can solve this issue.
eddieT
When browsing the Web, playing games, browsing fb & twitter, just for a few minutes my phone begins to overheat, even browsing this site my phone has started heating up. Once my phone starts overheating, my touch screen sensitivity goes for a ball of crap. Does anyone out there know how I can sort this out?
ghani667
Contributor
LOL Sony isint releasing that the heating issue is because of the kitkat  buggy update
qwe
Hey there, recently i had updated my xperia z1 to 4.4.2 its getting really hot while charging and using phone.. so i flash the stock firmware using flasher tool and downgrade it to 4.3 as there was no heating problem in it but i am getting the heating problem in this firmware too. previously in 4.3 all was good but now after downgrading 4.3 too gives problem of heating... plzzz help:-(
_alexdon_
Reinstall kit kat using sony update service:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
Drockk
Ihave same problem 😕
too much overheating
never buy sony again
