I am unable to locate "Extended Satndby Mode" in Power management. Can anybody Help ? I am attaching a screenshot
Okay, It is a Bug.It is already reported. Just ignore it and use Stamina Mode. Thank you. Kudos are welcomed
Assuming that you are using Xperia Z1, it has Stamina Mode which is accessible from Power management. Stamina Mode is way more efficient. Following link can be useful >>Z1 Stamina Mode
Ya Its Xperia Z1, I have turned ON Stamina Mode, But the problem is unable to lacate Extended Standby Mode. There's No such option in Power Management
Z1 has Stamina Mode and Low battery mode, they both function better than Extended Mode. New phones have Stamina Mode instead of Extended Mode. Follow the link provided for more info.
Ya thats true, but why the Phone asks to turn ON Extended STANDBY MODE ?? Sony should Fix it
Can you post the screen shot of notification stating about Extended Mode?
I have posted but its waiting for approval . . .
