I can't connect my ZR via Throw with my radio CMT-G2NiP
Bvw
I try to connect my ZR via Throw or AIrplay with my Sony Radio.
But it will not connet.
When I use Airplay the radio is saying Can not Join !!
How can I connect my ZR with my Radio so I can play music from my phne on the radio !!
Rickard
Master
I've read the manual for your radio and i suspect it doesn't work with Throw. I think you need to enable the media server in the phone under Settings -> More -> Media server settings and then access the phone from the radio by selecting Home network -> Options -> Refresh.
In order for Throw to work the radio must work as a DMR. See this thread for more information: http://talk.sonymobile.com/t5/FAQ/DLNA/m-p/351822
1 REPLY 1
Rickard
Master
