missing apps after update
Light2A
I can't find the sound recorder and small web browser
After updating the phone.
Update number: 14.1.G.2.257
Ashoksc19
Contributor
Some bug will fix after factory reset try this Settings-Backup & reset- Factory data reset.
If still you are facing the problem then
Repair your phone
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
3 REPLIES 3
Ashoksc19
Contributor
Repair your phone
PC Companion (PCC)
Bridge (for Mac)
Light2A
Thanks it works
Ashoksc19
Contributor
Glad to hear that
