Xperia ZL 4.2.2: Walkman controls and lock screen conflict
ylapas
Anyone is facing the problem of blinkink album art and Walkman controls while playing music on lock screen widgets? I looks as app conflict here because Walkman is trying to go on top of of clock widget and is rapidly blinking. Screenshot does not capture this, yet you can see to screens on top of each other and Walkman is the blinking one and is not the "winner" of lock screens battle Smiling_Face_with_open_mouth_&_closed_EyesScreenshot_2013-06-27-16-39-00.jpg
24 REPLIES 24
alejandrotrela
Yestarday while i was listening music with my bt handsfree i noticed the same issue:smileyshocked:
I had to close my music to work properly after that
Come on Sony everyday we discovered new issue with the byggy 4.2.2 version that you releace:smileyangry:
Also i m having problem with the level of brightness on lock screen when i set manualy the brightness and not responsive at all but work like i set it automaticly.
i write my issue but nobady from Sony answer
Give me a brake:smileywink:
aashutosh_diabl
Hey
I too just received the 4.2.2 update on Xperia Z and am facing the same flickering issue.
In my case it is too anoying as I have just encrypted my device so it is very disturbing when i enter the pin on the lock screen.
servarus
I hvae contacted SONY to monitor this thread and give some response. See how it goes.
Johan
Master
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
murzamuammar
I have too, walkman bug in lock screen, have anyone have to solve it
servarus
I have sent a PM to you.
servarus
Guys, I think I found the culprit.
Do you have Smart Key installed? I was cleaning up some apps, and after I uninstalled Smart Key, the lock screen worked properly.
Do give it a try and see how it goes.
ylapas
Yep, what solved this problem. Conclusion - Smartkey at least today is not compatible with Sony Xperia Z / ZL 4.2.2 Android version.
alejandrotrela
Not having smart key installed and stiil the preblem exist that s why i turn to 4,1,2 and everything work much better.
Until Sony releace proper 4.2.2 firmware i will stay with the previous version of Android version, because there is a lot off issue and not only the flickering in music control at lock screen.:smileywink:
ArijeetC
That's avast app. Can change its notification icon to grayscale.
