Z2 timer/countdown doesn't ring if screen is off or locked
briconaut
How to reproduce:
  • Start the default clock app.
  • Set the timer/countdown to 5s.
  • Choose a sound for the timer/countdown that has a duration of at least 2s.
  • Start the timer.
  • Press the Power key to turn off the screen or to lock the phone.
Result:
After about 5s, the timer alarm sounds for about 0.5s and is mute afterwards. If there's music playing in the background (from the walkman app), you may get just a short 'blank' in the audio stream (also about 0.5s long).
This beahavior occurs...
  • ... when the screen is off but the phone is unlocked.
  • ... when the screen is off and the phone is locked.
  • ... independend of the walkman app playing in the background.
Thies doesn't happen if the screen is on and the clock app is running in the foreground.
I've had no problems with the normal alarm (the ones you set to occur at a specific time).
What can I do?
12 REPLIES 12
CC4Smiles
Just tried that myself and you are correct... I also tried allowing the screen to turn itself off by setting the timer beyond my screen off time and the same thing occurs.
What software version are you currently running ?
I'm on the newest 23.0.1.A.0.167
briconaut
I'm also running 23.0.1.A.0.167.
The strange thing is, the normal alarm seems not to be affected by this.
CC4Smiles
Agreed, I use the alarm everyday and it functions correctly... Not sure what other options to explore, but then again I don't really use the Timer but that doesn't mean it shouldn't work as it should Slightly_frowning_Face
briconaut
A colleague has a Z2 with the software version 17.1.2.A.0.314. For him, the timer works fine. This is probably a bug with the newer software versions.
hoverdonkey
I have this problem too!
Android 4.4.4.  Build 23.0.1.A.0.167.
Flythe
Happens on my Xperia Z2 Tablet (SGP512, running Android 4.4.4/Build 23.0.1.A.4.30), too. ðŸ˜•
BK28
Is there a fix for this? I am starting to use the timer frequently, that's how I noticed the problem
Triffix
Yes, your description of this problem is very accurate and it is very annoying. I use the timer frequently when cooking and this problem have caused several runied dinners already 😞 This reminds me of the sleep of death problem with xperia V, only this problem is consistent. Please fix this or provide a solution.
haxilo
I have the same problem and I just can't stop myself thinking why is this problem still happening to us with such a huge company as SONY.. It's been months since this problem first noticed and still not fixed.. This kind of problems may seem like so little but it can make SONY loose custemers like me who are so annoyed by not feeling that they are cared at all..
