Misty pictures, on some commercials and permanent issue on all channel 4 broadcasts.
Toastybits
Hi, does anyone have issues with the above on their Sony KE48a9 ? thanks
daveyh64
Enthusiast
Channel 4 have still got issues after the problem at the Red Bee Media Broadcast Centre on the 25th September.
Why Channel 4 and Red Bee Media are taking so long to resolve this issue is puzzling, write to Channel 4 and tell them their broadcast is not to the same standard it was prior to the incident, and does not match the quality of broadcast you are receiving from other channels on your TV.
My Sony is exactly the same Channel 4 is brighter and lower contrast than other channels, it is not a
fault with the TV. If it were it would affect all channels.
2 REPLIES 2
royabrown2
Hero
@Toastybits
So perhaps not the YouView box then? 😛
daveyh64
Enthusiast
