My Vaio does not let me use my Network Walkman
VaioGeorgeVaio
Hi, if any one can help me with this it would be much appreciated.
I have had my NW-HD1 Network Walkman for a few years now. I recently purchased a Vaio laptop, installed SonicStage (V 2.1), but every time I try to do anything with SonicStage I get a message saying that I do not have persmission to do anything as I am not an Administrator. But I am an Administrator so cannot understand why I cannot proceed. As a result I cannot even access my Network Walkman music through my Vaio.
Any suggestions would be very wellcome
Thanks,
4 REPLIES 4
Blencogo
Hi Vaio George Vaio and welcome to Club Vaio.
Are you using Vista on your new Vaio? What model do you have?
I do not believe SonicStage Version 2.1 is Vista compatible.
You can see the capabilities of all the SonicStage versions here: -
http://www.sony.jp/products/overseas/contents/support/information/ss_difference.html
Looks like you may need version 4.3 or newer.
:thinking:
VaioGeorgeVaio
Hi Belencogo, thanks for getting back to me.
My Vaio model number is VGN-NR21E and it has Windows Vista installed.
What is the best way to proceed?
Your advice would be most welcome.
Thanks and best regards.
Blencogo
I would download SonicStage CP Version 4.3 for free from here: -
http://support.sony-europe.com/dna/downloads/downloads.aspx?l=en&f=sstage_dl
It says this version still supports your Network Walkman and Microsoft Vista.
The newer versions do compile libraries differently from the older versions - if you have any problems come back here and someone will fix it!!!
Good Luck.
:wink:
VaioGeorgeVaio
Version 4.3 of SonicStage did the trick!!!!!
Thank you very much for you help
Best regards.
