My phones screen won't come back on after making a call seems to be a proximity sensor fault.
As soon as I press the call button the screen goes blank even if it's not against my ear. If I press the power button it will come back on and then stay on even if I then press it to my ear.
Very annoying to be honest and I can't find a setting for it. I have tried Xperia Diagnostic It shows sensor is working.
Please help and Thanks
How can I send the feedback to Sony
Doest it also mean this can not be fixed and why i am suddenly start facing this issue. Must be because of buggy Android M
I tried this but still It is not helping. I remeber sony Z3 Zultra also have same problem. Somebody help me if this can be resolved.
In safe mode i am facing the same issue and I am facing from last 3 days (I guess Friday 2, Sep, 2016).
Will repairing software help becuase i don't want to delete my data.
Repairing the software can help, if it does it means that this was most likely software-related. If there was no change while in safe mode a software repair using Xperia Companion would be my next suggestion.
Since the repair will reset your device you can always create a backup using Xperia Companion first.
