I bought the Xperia Z ultra yesterday..... It makes me amazing features & I'm also really happy to got this amazing device... but It's 8 MP camera is really bad quality comparing with my old Xperia 10... xo many noise in back & front camera.. I don't know it's not included flash...
Can you guys improve camera quality with software updates???? if not, i will change another device....
based on all other Xperias Sony doesn't quite improve the camera that much with updates, my suggestion is since the Z Ultra doesn't have flash that you take your pictures in well lit areas.
I dun means like this... We can't take good photo in dark place bcoz there is no flash in the back camera... It's not mainly error.... Even under the good lighting, the camera produce a photo with noises & it doesn't show reality colour... for eg. I took the white colour wall photo, but it produce yellow colour instead of white...
which camera settings do you have?
all settings are same with Xperai Z... I captured with superior auto...
Thank you!! Colour is OK with your suggesstions... but how can i reduce noise??
could you post some pictures where you can see the noise, if you use burst mode it tends to reduce nosie
how to take screen shot??
No Screenshot option in power menu, means now you have to take screenshots by the combination of “Power + Volume down” button.
