i bought xperia z1 4-5 days ago
this phone is good but if i brouse web for 10 min it get super hot and even when calling it get hot
i have a Z1 and there is a problem , my mobile heats up so quickly while playing most of the games .. and camera stops working saying mobile is overheat , wat should i do ?? ..its going up to 47 degrees and even 50 degrees sometime ..its on latest 4.3 my games (clash of clans , asphalt 8 , dead trigger ) even while looking at pics in album app it heats up...plz respond to me if its a common problem plz fix it asap ...or if it is only to me suggest me what should i do ?? waiting for the response
My Z1 is heating up by just using whatsapp, email and facebook. what is the problem ? is it software problem or hardware ? Do i have to take it to the sony center ? I have just updated to the latest firmware 4.3... The heat is disturbing my camera and it is irritating when i cant take pictures when needed. Please ADVISE what should i do ?
same problem over here. i removed my 64 cheap micro sd card, it isn't overheating any more en charghing is ok. maybe give it a try.
still strange it can read it en it should support 64 gb
greetz
Probably you should consider buying other card,sony or sandisk.
I'm experiencing the same issue now. What should i do? I'm not expecting this unlike my MyPhone, its all good. Kindly help me. Please.
Boot your phone in safe mode and see if the same overheating problem occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Actually,the phone is supposed to heat when lots of processes are on at the same time.
