Z5 Microphone Problem
Djrick
Hey guys, I recently just purchased the Z5 on Black Friday and starting last night I've been experiencing a problem related to my microphone in that it isn't working. No one can hear me during calls or when you record videos.
I checked to see if there was microphone suppression settings but unfortunately there isn't any.
I want to see if I can fix it first before taking it in just because my old phone broke on Halloween and I went an entire month without a phone up until j got this one and so I'm trying to avoid letting it go.
Thanks in advance.
58 REPLIES 58
freaky1xd
I replaced the microphone flex cable myself and it still isn't working!
BassMuso
I Have also had a Z5 for 1 and a half years. Now the mic only works if I plug something in the mini-jack socket.
As soon as jack is unplugged, callers cannot hear me talking to them!
Seems there are a lot of posts from users having the same problem. Time to change to another brand of phone.....
BAlmeida
Same problem here!!!
Sad if I have to replace a almost new phone because of this!
Sandyv
I m also encountering same audio jack problem. Its a software problem so handset needs to be send to company for for repair within warrenty to prevent mony loss
But its alternate sol is download sound about app from where u can manually force the sound to earphone or to speakers it works but its seems quite irritating.
Coldheart79
Same problem here bought my Z5 compact in september 2016, started experience problems during spring sent it in for repair in May and got the mic replaced, worked ok but not good after that. However last week I started have similliar but worse problems with the mic as people could not hear me at all sometimes. So sent it in on repair again today, so we'll se what happens now. Also after the first repair the battery time as been awful now lasting less than a Day, also when using the phone it gets very hot.
Been buying Sony, since The Sony-Ericsson Xperia neo, but now thinking it might be my last one.
Sendmeback
Hey,
I was having this problem. Microphone barely picked up my voice and others couldn't hardly hear me during calls. Problem persisted in diagnostics and in safe mode.
Simply going to Settings-apps-google and then turning off its permissions to use microphones seemed to work wonders for me.
Hope this helps someone.
CanonHussey
I have a fault with my microphone on my Z5 where when I am calling someone they can't hear me. I have ran a diagnostic test on the microphone which it failed. Please could someone advise me ASAP. Thanks.
Porti_ec
In my case it started when I plug the earphones too, does anyone could fix this??
@OG1987 wrote:
I have this aswell, I think it might happen when you plug earphones in, then remove them, I think the phone thinks that a hands free is still attached so the mic is disabled... Have no idea how to fix it though... Any help Sony??
Etonboy
I have a Sony Experia E5 it is very annoying you talk to someone and they can't hear you I had an emergency one night and contacted emergency services I got through and they couldn't hear me. I had to restart the phone this is not right I have taken it to Vodafone who tested it and said it had a problem and send it away I need the phone for my work I am at the stage of changing the phone but I don't want to do this as I purchased it in August
Sandyv
Download the app soundabout to force the sound in earphone or speaker otw give it customer care they will change the motherboard
