How to turn off subtitles on a KD55XG8796BU
profile.country.IE.title
Teddykins89
Hi all,
I am having an issue with subtitles on my new TV and I hope you can advise.
I am unable to turn off the subtitles permanently on my new Sony Bravia KD55XG8796 TV.
I can turn them off whilst watching a channel but if I then switch channel they reappear without being switched on. Simililarly, if I return to a channel I had been watching and had already turned the subtitles off - they again reappear without being turned back on.
I have played around in the accessibility menu and found that subtitles are appearing as disabled as standard, but this is no the case in reality. I have to hit the (...) button to switch them off for each channel.
Can anyone advise how to permanently switch subtitles off as standard.
I think i may need a software patch or advanced settings.
Thanks in advance!
23 REPLIES 23
Joe_Dohn
Specialist
Have you tried checking the main settings of the TV under "Watching TV" or "Accessibility", I believe it may be called either Captions or Subtitle in those settings.
charlaw
Yes, tried that. The subtitle aren’t on using YouView to terrestrial, only on Freesat!
Sent from my iPad
Joe_Dohn
Specialist
Do you happen to be using an external set-top box for freesat or is the satellite cable connected directly to the TV tuner?
charlaw
Direct link to a satellite dish......
Sent from my iPad
Ajcarter57
There is no digital option
the accessibility option has subtitles a;ready turned off
Tried to turn it on and then off , not changed the subtitles
this is driving me mad !
Teddykins89
Settings>Watching TV>Channels>Channel setup>Digital Setup>Subtitle setup>Subtitle setting>Off
marlowhouse
Have just re-tuned Freesat on the TV and it seems to have cured the subtitles coming on each time I change channels.
charlaw
Hi
Thanks, just tried that but it didn’t work for me! Can’t understand why SONY can’t sort it!!
Sent from my iPhone
Joe_Dohn
Specialist
Have you tried checking out this Sony article?
charlaw
Tried this - doesn’t help! Sony fitted a new mother board and the subtitles went away for a few weeks but now back!
Only happens on Freesat and nothing seems to change the default being ‘on’
Sent from my iPhone
